简介
For a variety of reasons, a chain-link gate may become misaligned and unable or difficult to latch properly.
Thankfully, one of the most common causes of misalignment is the gradual shift of your gate hinges. This can be fixed quickly and with just an open end wrench or a pair of pliers, a marker, and a small carpenter’s level.
你所需要的
Use your open end wrench or pliers to loosen and remove the nuts on the bottom tension band.
Loosen and remove top tension band.
Remove and place gate to the side.
If your gate is still not latching properly or is sagging, you may need to disassemble your gate again and adjust the alignment or height of your hinges until the gate latches properly.
If the problem persists, it’s possible that your post wasn’t installed correctly, your fence may be experiencing pressure from structures leaning on it, or your nuts and bolts may be worn and deficient. These problems will require additional procedures.
2等其他人完成本指南。
2条评论
Thanks! Great detailed instructions and photos.
I read your guide and realized why our NEW fence from Lowes is a disaster!No bar on the bottom of the fence,so anyone can slide under it,LIKE MY DOGS DID LOWES!!!Thanks to your article I can now repair it right MYSELF.
Rob Harris - 回复
