跳转到主内容
Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler
你所需要的
  1. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 1 中的图像 1,3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 1 中的图像 2,3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 1 中的图像 3,3
    • Turn your label-maker on its face. Using your thumb, press in and then upward on the fastener located on the side of your device.
  2. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 2 中的图像 1,3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 2 中的图像 2,3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 2 中的图像 3,3
    • Remove the batteries from your device.
  3. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 3 中的图像 1,3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 3 中的图像 2,3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 3 中的图像 3,3
    • Using a plastic opening tool from your iFixit tool kit, leverage the label cartridge out of your device.
  4. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 4 中的图像 1,3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 4 中的图像 2,3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 4 中的图像 3,3
    • Press the label paper back into alignment with the small holders on the right side of the label cartridge.
  5. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 5 中的图像 1,3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 5 中的图像 2,3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 5 中的图像 3,3
    • Place the label cartridge and batteries back into your device. Refasten the bottom case of the label-maker.
  6. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 6 中的图像 1,3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 6 中的图像 2,3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 步骤 6 中的图像 3,3
    • Well done! You have successfully corrected the paper-jam in your Brother PT-90 Label-Maker.
结论
Kaitlyn Abrams
于10/13/16注册
1 声望
撰写一个指南
团队
University of Maine, Team 2-1, Diaz Fall 2016 University of Maine, Team 2-1, Diaz Fall 2016 的会员
UMAINE-DIAZ-F16S2G1
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 789
