跳转到主内容
Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm
你所需要的
  1. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm, Opening the Device: 步骤 1 中的图像 1,1
    • Flip device upside down and remove the 4 foam pads at each corner.
    • Remove the 4 screws using a Philips Screwdriver.
    • Gently lift the case off of the body and set down in a safe place.
  2. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm, Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: 步骤 4 中的图像 1,1
    • Unscrew the 5 screws in the base circuit board.
  3. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to slightly lift the circuit board, allowing the cylindrical alarm piece to slide out.
  4. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: 步骤 6 中的图像 1,1
    • Check if the wires are secured.
    • If they are not attached, you may re-solder it together. If they are attached, that means it is a faulty alarm and should replace it.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 47
总计 1,369
