你所需要的
open the right side of the Rockwheel's case, the side of the power switch. To access the screws, you need to pull the glued rubber protection a little. Once the case is open you'll see the PCB, the motherboard. You'll need to insert a jumper wire in two right holes on the bottom of the PCB.
即将完成!
结论
6等其他人完成本指南。
