跳转到主内容
Fix: makecab.exe runs for 5-10 minutes after every startup
  1. Fix: makecab.exe runs for 5-10 minutes after every startup, Find CBS log files folder: 步骤 1 中的图像 1,1
    • Find CBS log files folder. The folder usually contains a .log file under 2 GB, and some .cab files.
  2. Fix: makecab.exe runs for 5-10 minutes after every startup, Remove any .log files larger than 2 GB: 步骤 2 中的图像 1,2 Fix: makecab.exe runs for 5-10 minutes after every startup, Remove any .log files larger than 2 GB: 步骤 2 中的图像 2,2
    • Delete, or move away if you want to keep the logs, any .log files larger than 2 GB in the CBS folder.
    • If makecab.exe is currently running and processing the log files, you may need to end it through Task manager.
终点
4等其他人完成本指南。
Somnic
于07/13/18注册
195 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 13
总计 842
