你所需要的
按 Windows + R 快捷键调出“运行“窗口,输入”devmgmt.msc“,按”确认“。在弹出的窗口中展开”磁盘驱动器“,在”可移动存储介质“上右键,点击”更新驱动程序“。
如果有任何待安装的更新,跟随屏幕上的提示升级驱动程序。
有经验的用户在发现 Windows 没有检测到外部硬盘时,会检查磁盘管理中是否有这块盘。要打开磁盘管理工具,右键点击”这台电脑“(或 Windows 7 中的 "我的电脑"),在右键菜单中选择“管理”,进入计算机管理,然后在左边选择”磁盘管理“。
一旦驱动器盘符丢失,Windows 就无法识别该硬盘,但我们可以在 "计算机管理 "窗口中看到它。现在,我们必须为硬盘分配一个盘符,这样 Windows 才能识别它。
右键这个未被识别的硬盘,选择”更改驱动器号和路径“。
点击”添加“,选择一个未被使用的盘符,然后点击”确认“。
Bonjour, merci beaucoup pour ces conseils, j’en avais acheté un, je l’ai reporté car Windows ne le détectait pas, j’en ai eu un autre qu’il ne détectait pas non plus avant de tomber sur vos explications qui m’ont permis de le paramétrer.
When you assign a new drive letter, select a unique one,. If you already have a drive E. Choose a letter with no duplicates allowed,. Which leads to another possibility. Drive letter. Duplication, but you now know how to fix it! Its generally best not to change drive. Letters of your fixed disks which can break links to files and programs... not desirable.
If your drive shows up here, check to see also whether it is online or offline. If it shows offline right click there (on the left) and select online. This may fix it. You might run into this problem when there has been a drive letter conflict, since you can't have duplicated letters, one has to go,. Remember to assign a unique drive letter if there is none.
It did fix my problem, but the question is why it's doing it? It happens on Windows 7.
如果你看到了未识别的硬盘,并且它的空间是黑色背景,上面写着”未分配“,说明你的磁盘没有分区。你需要为其分区,然后 Windows 就可以正常识别它了。
我们知道,Windows 磁盘管理工具、diskpart 命令、MiniTool 分区向导等免费分区魔术师等不同工具都可以帮助创建分区。
If the drive is not new and contains. Data you want to ever see again DO NOT repatriation it. Try a different port, the one you're trying may not meet power requirements for the drive leading windows to give you bad advice... you might still. Recover data after a reformat but the more you perform any writes to the drive the fewer files will remain recoverable
众所周知,如果你把一块新的移动硬盘连接到电脑上,Windows 可能不会正确识别图它,因为你还没有对其进行格式化。按照前文所述的方式打开磁盘管理。
在这块磁盘的名称上右键,选择”格式化“,不用理会那些选项,直接点击”格式化“。
注意:在初始化过程中,系统会提示你选择是使用主引导记录(MBR)还是 GUID 分区表(GPT)作为东芝外置硬盘的分区样式。一般情况下,如果你的硬盘容量超过 2TB,最好选择 GPT,因为 MBR 不能利用 2TB 以上的硬盘空间,就像 32 位 Windows 最多只能使用 4GB 内存一样。如果你好奇为什么,分区表限制。
如果您的东芝外置硬盘被分区成错误的文件系统,您也会遇到外置硬盘无法识别 的问题。例如,你可能用 Linux 的 ext4 文件系统或 Mac 的 HFS Plus 文件系统格式化了硬盘。或者,你的驱动器文件系统被损坏,显示为 RAW。
但是,Windows 无法识别这些文件系统,所以你在资源管理器中看不到使用这些文件系统的磁盘。
首先,备份这块硬盘上的所有重要文件,然后,将硬盘格式化为 NTFS 格式或者 FAT32 格式,这样 Windows 就能识别它了。
Avoid fat32 since it does not support file sizes greater than 4GB which will cause file corruption. These days a file that large is not remarkable. Conversely if you'll be using the drive with an android device it won't see NTFS. Choose and remember the limitations.
为防止恶意软件感染造成问题,请首先扫描电脑,如果没有问题,再扫描外置硬盘。
禁用外部 USB 的自动执行功能,然后在尝试备份或恢复之前进行扫描。 你不会想要包含任何病毒。此步骤应在 Windows 可以看到硬盘时立即执行。
如果需要重新安装你的设备,请反向执行这份教程。
16等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
10条评论
All of the solutions revolve around the fact that diskmgmt.msc registered the device. My computer detected there was something in the USB port, just didn’t know what it was.
mine kept coming up with “redundant cycle error” and it wont do anything
My drive doesn’t show up in any of these solutions. The only place it shows up is I. Computer Management>Disc Drives.
Great little series of potential fixes (and if someone can read, they don’t need pics), but unfortunately, like some others, my brand new drive doesn’t show up anywhere at all. It was formatted on an 8.1 machine using Macrium with which I cloned a drive, which I am fairly certain was an NTFS type format. But, nada. Win 10 sucks again.
Thanks very much
Reassigning the drive letter fixed my issue. Many thanks!!
Comment faire si les anciens HD issuent de XP n’apparait pas SUR Windows 10?
I would not say this guide is outdated, the content is still germane and valid.
What about the FIX for if the drive is not detected in Disk Management either?
If you have the device not recognized, warning triangle icon right click it, select uninstall device then select Rescan from the drop-down menu above. If the drive is still not recognized try restarting your computer with the drive plugged in rather than attaching it after booting oddly, this sometimes works. Do try the drive in all your available ports, power issues port configurations may be the problem
Juan Garcia - 回复
Other things to try: NOT using a USB hub. A different cable. A different computer.
Juan Garcia - 回复
