跳转到主内容
Fix unresponsive iPhone X
  1. Fix unresponsive iPhone X, iPhone X: 步骤 1 中的图像 1,3 Fix unresponsive iPhone X, iPhone X: 步骤 1 中的图像 2,3 Fix unresponsive iPhone X, iPhone X: 步骤 1 中的图像 3,3
    • Go to Settings>Sounds&Haptics. All going well.
    • With the screen on, place a call to the phone using a known-good phone. The decline and answer buttons appear on the screen.
    • Turn the screen off. Place a call to the phone using a known-good phone. The phone is not responding at all. Press the power button to turn the screen on. We can see the decline and answer buttons on the screen.
  2. Fix unresponsive iPhone X: 步骤 2 中的图像 1,3 Fix unresponsive iPhone X: 步骤 2 中的图像 2,3 Fix unresponsive iPhone X: 步骤 2 中的图像 3,3
    • Judging by this, relevant circuits of the baseband wake signal might have malfunctioned. Take apart the phone and disconnect the battery. Remove the display assembly and take out the motherboard.
    • Attach the motherboard to the PCB Holder. Heat with Hot Air Gun at 200℃, air flow 3. Tear off the heat dissipation sticker on the backside of the motherboard.
    • Open the bitmap software. Locate BB_TO_PMU_PCIE_HOST_WAKE_L. Since relevant circuits of the wake signal might have malfunctioned, we can try to borrow the wake signal from WiFi relevant circuits.
    • Locate WLAN_TO_PMU_HOST_WAKE. We can connect PP101_E-1 (the test point of the baseband wake signal) with PP7611_W-1 (the test point of the WiFi wake signal) by jumping a wire.
  3. Fix unresponsive iPhone X: 步骤 3 中的图像 1,3 Fix unresponsive iPhone X: 步骤 3 中的图像 2,3 Fix unresponsive iPhone X: 步骤 3 中的图像 3,3
    • Scrape off the insulating coating on the two test points first. Then apply some solder paste to the two bonding pads. Heat with Soldering Iron at 365℃. Tin the two bonding pads with solder paste.
    • Connect PP101_E-1 to PP7611_W-1 with 0.02mm Enameled Copper Wire.
  4. Fix unresponsive iPhone X: 步骤 4 中的图像 1,2 Fix unresponsive iPhone X: 步骤 4 中的图像 2,2
    • Then coat the wire with the UV Curable Solder Mask.
    • Now we can assemble the phone and test. With the screen off, test again. All going well. Fault cleared.
结论
另外一个人完成了本指南。
REWA
于11/24/20注册
18,432 声望
创作了55篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 30
总计 716
