跳转到主内容
Fix a Loose Mounting Dream MD2462 TV Wall Mount
你所需要的
  1. Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 1 中的图像 1,3 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 1 中的图像 2,3 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 1 中的图像 3,3
    • Remove the two M4x5mm bolts on the back of the TV plate using a Phillips #00 screwdriver.
    • Unplug the TV cables before removing the TV from the wall.
  2. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 2 中的图像 1,3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 2 中的图像 2,3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 2 中的图像 3,3
    • Remove the three lag bolts from the wall mount by using a 13mm open-end wrench.
    • If it is too loose, it can just be pulled out.
  3. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 3 中的图像 1,3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 3 中的图像 2,3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 3 中的图像 3,3
    • Fill the holes where the screws were secured using drywall spackle.
  4. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 4 中的图像 1,1
    • Locate the wooden studs on the wall using a stud finder or knock on the wall to see if the stud is behind the wall.
  5. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 5 中的图像 1,3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 5 中的图像 2,3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 5 中的图像 3,3
    • Use a pencil to mark three holes on the wall.
    • Use a 3/8-inch drill bit to drill three holes at the marked positions.
    • Secure the wall mount into the wooden studs using new screws or bolts.
    • Ensure that all the screws are firmly secured to the wooden stud.
  6. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 6 中的图像 1,2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 6 中的图像 2,2
    • Test the firmness of the TV wall mount by gently pushing it up and down.
  7. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 7 中的图像 1,2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 7 中的图像 2,2
    • Gently replace the TV back on the wall mount.
  8. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 步骤 8 中的图像 1,1
    • Make sure the TV is secure and well-centered on the wall mount using a spirit level gauge to confirm the inclination.
结论
另外一个人完成了本指南。
Emmanuel Emedeke
于09/17/20注册
184 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 62
总计 4,992
