简介
Full solution on how to fix the Internal Error/Error 4000 and No Model Info messages on various Yamaha Receivers. This works with Yamaha RX-V673 and several other models.
Link to the current Yamaha firmware: https://europe.yamaha.com/en/support/upd...
视频介绍
即将完成!
结论
3等其他人完成本指南。
4条评论
I’ve been trying these steps on my Yamaha RX-A770 and when I press the info button to update via USB I get error “USB overloaded”. So I tried jumping the two connections in the same spot at R896 and it doesn’t appear to do anything, I continue to receive “Internal Error”. I’ve been searching all over and can’t find anything for this particular model and this error.
martin_dustin - 回复
i was messing with this receiver, too...First the internal Error, bridged the Points, set the Model and made an firmware update. This Update suxx somwhere at 97%. After i tried to start, i got the Rom Error. I used 4 different USB Sticks to made an update...sometimes it stopped at 10%, sometimes at 70%... I discovered a LOT of dirt on the pcb. So i took some isoproalc and cleades every lil feet of the chips mit a toothbrush. i dried it...started it and voila(!) Update has done without issues. I guess, the dirt on the pcb made some Problems...
Frank Bauer - 回复
I have a TSR-700 with internal error. Do the jumper thing and only shows the serial number, no the model. And the error is ModelDestError. Cant choose the model, only ------------ ---- shows
Rafael Mota Quintana - 回复
dears any help with this error on RX-V6A ? thanks
Olusola Ogundeji - 回复
