跳转到主内容
Fix 1kHz noise on a USB microphone
你所需要的
  1. Fix 1kHz noise on a USB microphone, Replace power smoothing capacitor for a larger one: 步骤 1 中的图像 1,2 Fix 1kHz noise on a USB microphone, Replace power smoothing capacitor for a larger one: 步骤 1 中的图像 2,2
    • Disassemble the microphone as in the video by a fellow hardware hacker https://www.youtube.com/watch?v=DDfCjkH2...
    • The key is; heat the glue - the glue is very tough and rubbery and strong - unlike regular melt stick glue. Be careful to not heat too much the mount in the middle that holds the microphone capsule. Pry-off the top, heat the glue, squeeze in the side grille into a spiral so it can be pulled out the top.
    • Remove screws of the separation plate and pull the board out. Its held in again with the same glue in the rails.
    • Note the capacitor is much smaller than the pads were designed for. For reasons I assume is - cost saving - the factory decided not to use three size of capacitor but just two.
    • Remove the capacitor and replace it with just a bigger one, perhaps from a donor board. Don't worry about the value - it just needs to smooth out the power supply rail for the FET. Ripples in the current are introduced as the devices sends USB packets every 1ms (at 1 kHz). This capacitor smooths those ripples out noticeably.
    • Do not test the microphone outside of its housing as all you'll hear is your typical 50Hz noise from the electrical system.
结论
另外一个人完成了本指南。
martin-kokos
于08/26/24注册
100 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 226
