跳转到主内容
Fitted Bed Sheet Elastic Replacement
你所需要的
  1. Fitted Bed Sheet Elastic Replacement, Elastic: 步骤 1 中的图像 1,3 Fitted Bed Sheet Elastic Replacement, Elastic: 步骤 1 中的图像 2,3 Fitted Bed Sheet Elastic Replacement, Elastic: 步骤 1 中的图像 3,3
    • Make a small cut in elastic casing at the edge of the fabric seam to access the elastic inside.
    • With your sewing scissors, carefully cut the stitches that attach the elastic to the fabric, if sewn in place.
    • On some sheets, the elastic isn’t sewn directly to the fabric—it’s threaded through a casing and can be pulled out.
    • Gently pull the elastic to detach it from the fabric.
    • Continue cutting and pulling the elastic until it completely detaches from the casing.
  2. Fitted Bed Sheet Elastic Replacement: 步骤 2 中的图像 1,2 Fitted Bed Sheet Elastic Replacement: 步骤 2 中的图像 2,2
    • Use a measuring tape, to measure the length of the old elastic.
    • Keep the elastic as flat and straight as possible to get an accurate measure. This will help you determine the length of the new elastic.
  3. Fitted Bed Sheet Elastic Replacement: 步骤 3 中的图像 1,2 Fitted Bed Sheet Elastic Replacement: 步骤 3 中的图像 2,2
    • Lay the new elastic flat on a table. Use the old elastic as a reference, measure the same length with a measuring tape, and mark it with tailor's chalk.
    • If your old elastic was overly damaged, shorten the length by 1-2 inches to ensure tightness.
    • With sewing scissors, cut the new elastic at the marked length.
    • If you are unsure of the length, you can start with a longer piece and trim the excess afterwards.
  4. Fitted Bed Sheet Elastic Replacement: 步骤 4 中的图像 1,2 Fitted Bed Sheet Elastic Replacement: 步骤 4 中的图像 2,2
    • Overlap the ends of the new elastic.
    • If you need, pin them to keep them secure.
    • With your sewing machine, sew the ends securely using a straight stitch to ensure strength under tension.
    • Ensure the elastic lies flat and isn't twisted before sewing.
  5. Fitted Bed Sheet Elastic Replacement: 步骤 5 中的图像 1,3 Fitted Bed Sheet Elastic Replacement: 步骤 5 中的图像 2,3 Fitted Bed Sheet Elastic Replacement: 步骤 5 中的图像 3,3
    • Align the elastic along the edge of the sheet, about 1/2 inch from the edge.
    • Use pins to keep it in place.
    • Secure the elastic with an anchor stitch by sewing back and forth a few times to hold it in place and prevent the elastic from shifting as you sew.
    • Start folding the fabric over the elastic to create a casing. Fold the fabric far enough to cover the elastic.
    • Sew along the folded edge with a straight stitch, gently stretching the elastic as you go.
    • Keep your elastic centered inside the fold.
    • Work in small sections as you fold, stretch, and sew.
  6. Fitted Bed Sheet Elastic Replacement: 步骤 6 中的图像 1,2 Fitted Bed Sheet Elastic Replacement: 步骤 6 中的图像 2,2
    • When you've sewn the elastic all the way around, make a small stitch by sewing back and forth where the ends meet.
    • Give the sheet a stretch to ensure the elastic can move freely and gather the fabric evenly.
    • Inspect the entire seam to ensure it's holding the elastic securely. If you see any skipped stitches or loose spots, reinforce them with a few extra passes with your sewing machine.
结论
Jen43
于04/09/25注册
141 声望
撰写一个指南
团队
CSU Los Angeles, Team 5-43, Harris Spring 2025 CSU Los Angeles, Team 5-43, Harris Spring 2025 的会员
CSULA-HARRIS-S25S5G43
1 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 40
过去 30 天: 174
总计 954
