跳转到主内容
Fitbit Surge GPS Replacement
你所需要的
  1. Fitbit Surge GPS Replacement, Fitbit Surge GPS Replacement: 步骤 1 中的图像 1,2 Fitbit Surge GPS Replacement, Fitbit Surge GPS Replacement: 步骤 1 中的图像 2,2
    • Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge GPS Replacement: 步骤 2 中的图像 1,3 Fitbit Surge GPS Replacement: 步骤 2 中的图像 2,3 Fitbit Surge GPS Replacement: 步骤 2 中的图像 3,3
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: Once the band is cut it cannot be reattached.
  3. Fitbit Surge GPS Replacement: 步骤 3 中的图像 1,2 Fitbit Surge GPS Replacement: 步骤 3 中的图像 2,2
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge GPS Replacement: 步骤 4 中的图像 1,2 Fitbit Surge GPS Replacement: 步骤 4 中的图像 2,2
    • Use a PH000 screw head to undo the newly revealed 4 mm Phillips screws that were hidden beneath the glue.
结论
To reassemble your device, follow these instructions in reverse order. Keep in mind that you will need to cut the band for this guide and it cannot be reattached.
3等其他人完成本指南。
Angela Pitts
于10/11/16注册
1,187 声望
创作了4篇指南
团队
USF Tampa, Team 1-3, Leahy Fall 2016 USF Tampa, Team 1-3, Leahy Fall 2016 的会员
USFT-LEAHY-F16S1G3
3 名成员
创作了4篇指南
一条评论
Where do you get the parts to replace the GPS or the screen ?
Christine Arends - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 2,961
