本指南有最近更改,您可查看未经巡查的最新版本。
简介
Is your Fitbit Surge battery not charging no matter what you do? Read this guide to learn how to replace the battery, but keep in mind that you will need to cut the wristband in order to complete this repair and the band cannot be reattached.
你所需要的
Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
To reassemble your device, follow these instructions in reverse order. Keep in mind that the band will need to be cut for this repair and it cannot be reattached.
11等其他人完成本指南。
10条评论
I'm about to embark on replacing the battery for my fitbit surge. After having it for over 2 years it requires a charge about twice a day which get annoying.
Does removing/replacing the battery require the moderate soldering skill?
Looks like it must.
Chaspsmith - 回复
The last photo I think shows the tool prying the force feedback motor, the battery is the white plastic covered slim brick on the top right.
You do not need to cut bands off
Tim master - 回复
The replacement battery for the Fitbit Surge can be found here:
It also includes all of the tools (except soldering iron) needed for the repair.
