跳转到主内容
加入维修社区 - 创建账户
Fitbit Surge Battery Replacement
你所需要的
  1. Fitbit Surge Battery Replacement, Battery: 步骤 1 中的图像 1,2 Fitbit Surge Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge Battery Replacement: 步骤 2 中的图像 1,3 Fitbit Surge Battery Replacement: 步骤 2 中的图像 2,3 Fitbit Surge Battery Replacement: 步骤 2 中的图像 3,3
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: The band cannot be reattached once it is cut.
  3. Fitbit Surge Battery Replacement: 步骤 3 中的图像 1,2 Fitbit Surge Battery Replacement: 步骤 3 中的图像 2,2
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge Battery Replacement: 步骤 4 中的图像 1,2 Fitbit Surge Battery Replacement: 步骤 4 中的图像 2,2
    • Use a PH000 screw head to undo the newly revealed silver 4 mm Phillips screws that were hidden beneath the glue.
  5. Fitbit Surge Battery Replacement: 步骤 5 中的图像 1,2 Fitbit Surge Battery Replacement: 步骤 5 中的图像 2,2
    • Using a metal spudger, push down on the plastic gray square clamps on the underside of the device to dislodge the whole silver backing.
    • Note: the buttons will also come off.
  6. Fitbit Surge Battery Replacement: 步骤 6 中的图像 1,1
    • Use a pick or small flathead to remove the 4 metal clamps holding device together.
    • Use a thin tool to pry the the device apart by lodging it between the clock face and back side of the device.
    • Note: a spudger may not be thin enough to fit in the seam of the device. We used the 6 inch metal ruler from the Pro Tech Toolkit.
    • Go slowly and carefully disconnect two cables before fully opening.
  7. Fitbit Surge Battery Replacement: 步骤 7 中的图像 1,1
    • Gently remove the battery.
结论
To reassemble your device, follow these instructions in reverse order. Keep in mind that the band will need to be cut for this repair and it cannot be reattached.
11等其他人完成本指南。
Angela Pitts
于10/11/16注册
1,190 声望
创作了4篇指南
团队
USF Tampa, Team 1-3, Leahy Fall 2016 USF Tampa, Team 1-3, Leahy Fall 2016 的会员
USFT-LEAHY-F16S1G3
3 名成员
创作了4篇指南
10指南评论
I'm about to embark on replacing the battery for my fitbit surge. After having it for over 2 years it requires a charge about twice a day which get annoying.
Does removing/replacing the battery require the moderate soldering skill?
L “Rico” Hirano - 回复 分享
Looks like it must.
Chaspsmith - 回复 分享
The last photo I think shows the tool prying the force feedback motor, the battery is the white plastic covered slim brick on the top right.
csaba.toth.us - 回复 分享
You do not need to cut bands off
Tim master - 回复 分享
The replacement battery for the Fitbit Surge can be found here:
It also includes all of the tools (except soldering iron) needed for the repair.
michaelf33707 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 86
总计 20,624
