跳转到主内容
Fitbit Inspire 2 Wrist Straps Replacement
你所需要的
  1. Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: 步骤 1 中的图像 1,3 Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: 步骤 1 中的图像 2,3 Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: 步骤 1 中的图像 3,3
    • Use a spudger or your fingernail to push back the release lever on one of the two straps on the underside of the Fitbit.
    • You may experience some resistance from the release, but don't use excessive force, as it may damage the release levers.
  2. Fitbit Inspire 2 Wrist Straps Replacement: 步骤 2 中的图像 1,3 Fitbit Inspire 2 Wrist Straps Replacement: 步骤 2 中的图像 2,3 Fitbit Inspire 2 Wrist Straps Replacement: 步骤 2 中的图像 3,3
    • As you pull back the release lever, shift the strap diagonally.
    • Remove from the Fitbit strap.
    • Repeat the process for the other strap.
  3. Fitbit Inspire 2 Wrist Straps Replacement: 步骤 3 中的图像 1,2 Fitbit Inspire 2 Wrist Straps Replacement: 步骤 3 中的图像 2,2
    • Now that the old straps are detached from the Fitbit, take the opportunity to clean the watch and strap connection points.
    • Use a spudger to clean the inside of the strap chamber. Scrape out any residue or grime that may have built up over the past months or years.
  4. Fitbit Inspire 2 Wrist Straps Replacement: 步骤 4 中的图像 1,1
    • Slide the replacement straps into the given slot and the lever will click back into place.
  5. Fitbit Inspire 2 Wrist Straps Replacement: 步骤 5 中的图像 1,2 Fitbit Inspire 2 Wrist Straps Replacement: 步骤 5 中的图像 2,2
    • The straps should be secure and you can wear your watch again!
结论
2等其他人完成本指南。
MarcSerpa
于01/09/24注册
142 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 582
