跳转到主内容
Fitbit Charge HR Vibration Motor Replacement
你所需要的
  1. Fitbit Charge HR Vibration Motor Replacement, Vibration Motor: 步骤 1 中的图像 1,1
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Vibration Motor Replacement: 步骤 2 中的图像 1,3 Fitbit Charge HR Vibration Motor Replacement: 步骤 2 中的图像 2,3 Fitbit Charge HR Vibration Motor Replacement: 步骤 2 中的图像 3,3
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Vibration Motor Replacement: 步骤 3 中的图像 1,1
    • Remove the motherboard assembly from the device by gently lifting.
  4. Fitbit Charge HR Vibration Motor Replacement: 步骤 4 中的图像 1,2 Fitbit Charge HR Vibration Motor Replacement: 步骤 4 中的图像 2,2
    • Locate the vibration motor on the motherboard.
    • Desolder the red and black wires connected to the motherboard from the vibration motor.
    • Red wire is located closer to the outside. Black wire is closer to the inside of the motherboard.
    • Replace with new vibration motor.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 15
总计 405
