跳转到主内容
Fitbit Charge HR Screen Replacement
你所需要的
  1. Fitbit Charge HR Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Screen Replacement: 步骤 2 中的图像 1,3 Fitbit Charge HR Screen Replacement: 步骤 2 中的图像 2,3 Fitbit Charge HR Screen Replacement: 步骤 2 中的图像 3,3
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Screen Replacement: 步骤 3 中的图像 1,2 Fitbit Charge HR Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the motherboard assembly from the device.
    • Flip the motherboard over so the screen is facing upwards.
  4. Fitbit Charge HR Screen Replacement: 步骤 4 中的图像 1,3 Fitbit Charge HR Screen Replacement: 步骤 4 中的图像 2,3 Fitbit Charge HR Screen Replacement: 步骤 4 中的图像 3,3
    • Wedge a nylon spudger between the screen and the motherboard.
    • Gently pry the screen up and remove it from the motherboard.
    • Metal spudgers can puncture an unprotected battery and damage components like the motherboard. Always choose a tool that's ESD-safe, such as a nylon spudger or plastic opening tool.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 23
总计 752
