跳转到主内容
Fitbit Charge HR Battery Replacement
你所需要的
  1. Fitbit Charge HR Battery Replacement, Fitbit Charge HR weak Battery Repair / Replacement tutorial: 步骤 1 中的图像 1,2 Fitbit Charge HR Battery Replacement, Fitbit Charge HR weak Battery Repair / Replacement tutorial: 步骤 1 中的图像 2,2
    • Inside your Fitbit Charge HR
  2. Fitbit Charge HR Battery Replacement, Tools needed to replace Fitbit Charge HR battery: 步骤 2 中的图像 1,1
    • You'll need some plastic bits to separate the band, plus a torx driver, new battery and a soldering iron.
  3. Fitbit Charge HR Battery Replacement: 步骤 3 中的图像 1,1
    • This repair only works on the Fitbit Charge HR model, not the older Charge without heart rate. The batteries are different.
  4. Fitbit Charge HR Battery Replacement, Separate the band from the electronics casing: 步骤 4 中的图像 1,1
    • Start by removing the 4 torx screws
  5. Fitbit Charge HR Battery Replacement, Take your time and be careful of the fragile plastic: 步骤 5 中的图像 1,1
    • The assembly is briskly snapped into place. You'll need to separate the sides of the housing with a small plastic tool and your finger nail (or two plastics). Be careful, as the housing can fracture with too much force.
  6. Fitbit Charge HR Battery Replacement, A small torx driver is required.: 步骤 6 中的图像 1,2 Fitbit Charge HR Battery Replacement, A small torx driver is required.: 步骤 6 中的图像 2,2
    • Once removed, there are 2 torx screws holding the circuit board in place. Remove these, and carefully pry the board out
  7. Fitbit Charge HR Battery Replacement, Prepare to solder!: 步骤 7 中的图像 1,2 Fitbit Charge HR Battery Replacement, Prepare to solder!: 步骤 7 中的图像 2,2
    • The Fitbit is very light, and hard to hold, so I recommend taping the board in place when soldering.
  8. Fitbit Charge HR Battery Replacement, Understand the risk to your device.: 步骤 8 中的图像 1,1
    • Note: You can permanently damage your device. Be careful with the assembly, and splice one or both wires before removing the old battery to prevent a short. Do not mistake the round buzzer for a battery. It is not !
  9. Fitbit Charge HR Battery Replacement, Test your work before you re-assemble.: 步骤 9 中的图像 1,1
    • After replacing the bad battery, plug in the charger for at least 20 minutes. Then remove the charger to confirm you have a working replacement.
结论
33等其他人完成本指南。
martysummer
于02/18/13注册
943 声望
撰写一个指南
21条评论
if you have the manual dexterity and intellect to replace the battery on a Fit bit Charge HR, why can't you do it on. "Charge" plain model I have 3 of these with dead batteries?
coljwm - 回复
The battery on the original Fitbit tracker is different than the newer Fitbit HR. If you can find a battery that fits, it would work.
martysummer - 回复
Where can I buy a replacement battery for my charge hr? Fitbit wants me to buy a new Fitbit which is inexcusable since the watch is only 16 months old
Evan - 回复
They sell them on Amazon for $10.95. Has only one review for 2 stars. Trying to decide if I should order one. Caveat emptor!
Scott McKernon -
Can you give me the size of the battery?
Bajmóczy Géza - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 87
过去 30 天: 420
总计 150,635
