跳转到主内容
Fitbit Alta HR Battery Replacement
你所需要的
  1. Fitbit Alta HR Battery Replacement, Remove straps: 步骤 1 中的图像 1,2 Fitbit Alta HR Battery Replacement, Remove straps: 步骤 1 中的图像 2,2
    • Push in the clip and slide off the strap from each side.
  2. Fitbit Alta HR Battery Replacement, Remove front cover: 步骤 2 中的图像 1,1
    • Use a spudger to remove the front cover.
  3. Fitbit Alta HR Battery Replacement, Lift display: 步骤 3 中的图像 1,1
    • Use a spudger to lift the display.
  4. Fitbit Alta HR Battery Replacement, Disconnect heart rate monitor: 步骤 4 中的图像 1,1
    • Use a spudger to disconnect the cable that connects the heart rate monitor to the motherboard.
  5. Fitbit Alta HR Battery Replacement, Remove screws from motherboard: 步骤 5 中的图像 1,1
    • Use a hex 0.7 screwdriver to remove the screws from the motherboard.
  6. Fitbit Alta HR Battery Replacement, Lift motherboard: 步骤 6 中的图像 1,2 Fitbit Alta HR Battery Replacement, Lift motherboard: 步骤 6 中的图像 2,2
    • Use a spudger to lift the motherboard.
  7. Fitbit Alta HR Battery Replacement, Lift battery and remove innards: 步骤 7 中的图像 1,1
    • Use a spudger to lift the battery.
    • When the battery is lifted, the connected components (display, motherboard, battery) will come out.
    • Use a soldering iron to desolder the two battery contacts from the motherboard.
    • Ensure positive and negative wires are in the correct positions. There are + and – signs on the motherboard. Red is positive. Black is negative.
    • Use a soldering iron and lead-free solder to solder the new battery to the motherboard.
结论
3等其他人完成本指南。
Wendy Sato
于11/12/16注册
229 声望
撰写一个指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 79
总计 1,723
