跳转到主内容
Fishing Line Replacement
  1. Fishing Line Replacement, Fishing Line: 步骤 1 中的图像 1,1
    • Thread fishing line through all eyelets on the fishing pole.
  2. Fishing Line Replacement: 步骤 2 中的图像 1,1
    • At the top of the allotted seven to ten feet, thread the line through one hook of the bobber by depressing the opposite side of the bobber so that the hook is exposed.
  3. Fishing Line Replacement: 步骤 3 中的图像 1,1
    • Repeat step two for the opposite end of the bobber, threading the line through the second hook.
  4. Fishing Line Replacement: 步骤 4 中的图像 1,1
    • About one to two feet before the end of the line, thread a weight onto the line.
  5. Fishing Line Replacement: 步骤 5 中的图像 1,1
    • Tie a knot around the weight's eyelet. (No specific knot needed, it just needs to stay in place.)
  6. Fishing Line Replacement: 步骤 6 中的图像 1,1
    • At the very end of the line, thread the line through the eyelet of the lure about 6 inches.
  7. Fishing Line Replacement: 步骤 7 中的图像 1,1
    • Twist the line around itself approximately five to six times.
  8. Fishing Line Replacement: 步骤 8 中的图像 1,1
    • Thread the remaining line through the hole created by the previous step near the lure eyelet.
  9. Fishing Line Replacement: 步骤 9 中的图像 1,1
    • Pull the knot tight.
结论
After step 9 you are ready to fish.
Trevone Martin
于02/22/18注册
169 声望
撰写一个指南
一条评论
This is Joe from Durban Deep Sea Fishing Charters. This is a short and concise but very helpful guide to replace a fishing line. I will be sure to share this with my clients. Thanks guys
Joe Osborne - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 50
总计 1,436
