简介
This guide will show you how to remove and replace a blown speaker. Doing this will require a phillips head screwdriver and wire cutters. A soldering tool will also be needed to reattach wires to the new speaker.
你所需要的
Use a Phillips #0 screwdriver to remove the two 25mm screws that secure back panel to amplifier.
To reassemble your device, use soldering link provided to solder existing wires onto new speaker, then follow these instructions in reverse order.
另外一个人完成了本指南。
