跳转到主内容
Firmware update or recovery - PC (All models)
你所需要的
  1. Firmware update or recovery - PC (All models), Plug the controller in: 步骤 1 中的图像 1,1
    • Connect the controller using a USB-C OR MicroUSB cable. Plug the controller into a USB port on your PC.
    • Bluetooth firmware updates are not supported.
  2. Firmware update or recovery - PC (All models), Download the Xbox Accessories app.: 步骤 2 中的图像 1,2 Firmware update or recovery - PC (All models), Download the Xbox Accessories app.: 步骤 2 中的图像 2,2
    • Download the Xbox Accessories app from Microsoft Store using this link.
    • After it has finished downloading, you can launch it either straight off the app's page or from your Start Menu.
  3. Firmware update or recovery - PC (All models), Prepare the app for the firmware update: 步骤 3 中的图像 1,2 Firmware update or recovery - PC (All models), Prepare the app for the firmware update: 步骤 3 中的图像 2,2
    • After you launch the app and it finishes loading, the controller should show up like on the first photo.
    • Click on the three dots under the Configure button.
    • If the button over the Buzz/Vibrate this controller says No update available, your controller is already up to date and the guide ends here.
  4. Firmware update or recovery - PC (All models), Update the firmware: 步骤 4 中的图像 1,2 Firmware update or recovery - PC (All models), Update the firmware: 步骤 4 中的图像 2,2
    • Press the Continue button and wait for the process to finish.
    • In most cases, the firmware can be recovered, but be careful not to disconnect the controller during the update. Any loss of connection, be it disconnecting or PC power loss may damage the controller beyond repair.
    • After the update, press Close. Your controller is now up to date and should be fully usable with your PC, Xbox One or Series S/X consoles.
终点
6等其他人完成本指南。
SojerManLan
于07/07/21注册
253 声望
撰写一个指南
1指南评论
Use this video if you need to undo anything.
Revert Firmware
go away - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 43
过去 30 天: 153
总计 6,096
