当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Disconnect the electric plug from the wall.
Turn off or push down off water main valve from the wall.
Remove the back panel with 6 screws from the back panel using a 8 mm nut driver.
Disconnect the water supplied line from the refrigerator using two 13 mm open-end wrenches.
Use a little bucket to receive the water from the water lines.
Disconnect the water line from the water inlet valve using and open-end wrench size 15mm
Disconnect the water line cover removing 2 screws using a 7 mm nut driver.
Pull up the gum seal compound.
Push the left side of the filter cover and pull it straight out.
Remove the 2 screws on top of the housing using 7 mm nut driver.
Pull the housing and filter out slowly.
Remove the filter by turn it counterclockwise
取消:我没有完成这个指南。
与2其他贡献者
于09/18/16注册
2 声望
撰写一个指南
徽章: 2
PHSC-PRINCE-F16S5G1
1 名成员
创作了1篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 27
总计 2,109
