跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Due to long time use of the gear buttons, the components inside start to work poorly. This leads to unability to change gears while driving.
For the button replacement, just go on to the Farnell website and type in the reference code 1656426 which points to a ALPS SKHHLMA010. This one is a little softer than the original one but do the job perfectly.
If you wish to have one which is firmer then try this one 1656427 (ALPS SKHHLNA010) or even this one 1656428 (ALPS SKHHLPA010, but maybe really too firm...).
配件
没有特定配件。
  1. Disassembly the steering wheel (see the Disassembly Guide)
    • Disassembly the steering wheel (see the Disassembly Guide)
  2. Manta 螺丝刀工具包
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  3. Put the steering wheel as shown on the photo and unscrew as indicated. Put the steering wheel as shown on the photo and unscrew as indicated.
    • Put the steering wheel as shown on the photo and unscrew as indicated.
结论
另外一个人完成了本指南。
Remy
于2011年02月19日注册
120 信誉积分
撰写一个指南
Hi Remy,
I have request, could you make photo your wheel inside.
Many thanks.
szaro - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 9
过去的30天: 33
总计 4,332
