跳转到主内容
Bomann DB 774CB Iron
你所需要的
  1. Bomann DB 774CB Iron, Startup: 步骤 1 中的图像 1,1
    • Locate and extract the small plug (circled in the photo) and remove the screw hidden underneath.
    • Unscrew and remove the back plate.
  2. Bomann DB 774CB Iron, Undressing the handle: 步骤 2 中的图像 1,3 Bomann DB 774CB Iron, Undressing the handle: 步骤 2 中的图像 2,3 Bomann DB 774CB Iron, Undressing the handle: 步骤 2 中的图像 3,3
    • Unclip the top of the handle from the back (clips circled in the photos).
    • Unclip the top of the handle from the front (clips circled in the photo). Be careful not to break (like us) the steam nozzle!
    • Pull out the steam control knobs.
    • Carefully "tear" the temperature adjustment knob.
  3. Bomann DB 774CB Iron, Stripping of the sole: 步骤 3 中的图像 1,2 Bomann DB 774CB Iron, Stripping of the sole: 步骤 3 中的图像 2,2
    • Remove the screws and remove the plastic shell.
    • Unscrew the screws and remove the base cover.
  4. Bomann DB 774CB Iron, Breakdowns: 步骤 4 中的图像 1,1
    • Two different failures already observed:
    • Spacer (circled) which had come out of its housing following a fall of the iron!
    • Small foreign body that got stuck between the two contacts (circled).
    • Be careful not to turn the temperature adjustment screw (arrow) located in the control rod. Its readjustment is quite tedious, by mistake and trials!
结论
Putting each screw back in its place is no problem.
6等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
HelloMacOS正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Louis Possoz
于01/10/15注册
435 声望
创作了3篇指南
团队
Repair Café Louvain-la-Neuve Repair Café Louvain-la-Neuve 的会员
Repair Café
2 名成员
创作了6篇指南
一条评论
Do you instructions in English
Nur Haque - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 36
总计 2,934
