跳转到主内容
Fender Starcaster String Removement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Fender Starcaster String Removement, Loosen the Strings: 步骤 1 中的图像 1,3 Fender Starcaster String Removement, Loosen the Strings: 步骤 1 中的图像 2,3 Fender Starcaster String Removement, Loosen the Strings: 步骤 1 中的图像 3,3
    • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
    • Repeat this for all six strings on the guitar.
  2. Fender Starcaster String Removement, Remove the Strings from the Tuning Pegs: 步骤 2 中的图像 1,2 Fender Starcaster String Removement, Remove the Strings from the Tuning Pegs: 步骤 2 中的图像 2,2
    • Be mindful of the string ends. They may be sharp and could puncture your skin.
    • It may be necessary to use pliers to remove string ends from the tuning peg.
  3. Fender Starcaster String Removement, Remove the Strings from the Bridge: 步骤 3 中的图像 1,3 Fender Starcaster String Removement, Remove the Strings from the Bridge: 步骤 3 中的图像 2,3 Fender Starcaster String Removement, Remove the Strings from the Bridge: 步骤 3 中的图像 3,3
    • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
    • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
终点
另外一个人完成了本指南。
团队
Pasco Hernando, Team 5-3, Prince Fall 2014 Pasco Hernando, Team 5-3, Prince Fall 2014 的会员
PHSC-PRINCE-F14S5G3
9 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,363
