跳转到主内容
Fender Starcaster Pickguard Removal
你所需要的
  1. Fender Starcaster Pickguard Removal, Loosen the Strings: 步骤 1 中的图像 1,3 Fender Starcaster Pickguard Removal, Loosen the Strings: 步骤 1 中的图像 2,3 Fender Starcaster Pickguard Removal, Loosen the Strings: 步骤 1 中的图像 3,3
    • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
    • Repeat this for all six strings on the guitar.
  2. Fender Starcaster Pickguard Removal, Remove the Strings from the Tuning Pegs: 步骤 2 中的图像 1,2 Fender Starcaster Pickguard Removal, Remove the Strings from the Tuning Pegs: 步骤 2 中的图像 2,2
    • Be mindful of the string ends. They may be sharp and could puncture your skin.
    • It may be necessary to use pliers to remove string ends from the tuning peg.
  3. Fender Starcaster Pickguard Removal, Remove the Strings from the Bridge: 步骤 3 中的图像 1,3 Fender Starcaster Pickguard Removal, Remove the Strings from the Bridge: 步骤 3 中的图像 2,3 Fender Starcaster Pickguard Removal, Remove the Strings from the Bridge: 步骤 3 中的图像 3,3
    • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
    • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
  4. Fender Starcaster Pickguard Removal, Remove the Knobs: 步骤 4 中的图像 1,1
    • While it is not necessary to remove the potentiometer knobs in order to remove the pickguard, it is much easier to remove them while the pickguard is attached to the guitar.
    • The knobs are removed simply by pulling up on them. Be mindful not to pry too much, as older components may feel stuck at first, and you do not want to break the pickguard, knob, or potentiometer.
  5. Fender Starcaster Pickguard Removal, Remove the Selector Switch Cap: 步骤 5 中的图像 1,2 Fender Starcaster Pickguard Removal, Remove the Selector Switch Cap: 步骤 5 中的图像 2,2
    • As with the knobs, the switch cap may be removed prior to removing the pickguard.
    • Grip the cap firmly, and pull up to remove it from the switch. Be aware that the switch may move, and to be careful so that you do not break it.
  6. Fender Starcaster Pickguard Removal: 步骤 6 中的图像 1,2 Fender Starcaster Pickguard Removal: 步骤 6 中的图像 2,2
    • Once the cap and knobs have been removed, you may begin removing the screws around the perimeter of the pickguard.
    • Do not remove the screws on the electronics.
  7. Fender Starcaster Pickguard Removal, Remove the Pickguard: 步骤 7 中的图像 1,3 Fender Starcaster Pickguard Removal, Remove the Pickguard: 步骤 7 中的图像 2,3 Fender Starcaster Pickguard Removal, Remove the Pickguard: 步骤 7 中的图像 3,3
    • Gently lift up on the pickguard. With the screws removed, it should be loose, and easily pulled off of the guitar body.
    • Carefully rotate the pickguard away from the guitar. Notice the electronics. There is a wire that runs through the body to the output jack.
结论
团队
Pasco Hernando, Team 5-3, Prince Fall 2014 Pasco Hernando, Team 5-3, Prince Fall 2014 的会员
PHSC-PRINCE-F14S5G3
9 名成员
创作了10篇指南
一条评论
This process describes only how to access the internals of the guitar — how to MOVE the pick guard. NOT how to actually REMOVE it, as indicated in the title. And removing it is what is required if we were talking about 'removing the pick guard...to change the style,' as noted in the introduction.
stantondvx - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 23
过去 30 天: 87
总计 5,916
