跳转到主内容
Fender Jazz Bass Strings Replacement
你所需要的
  1. Fender Jazz Bass Strings Replacement, Strings: 步骤 1 中的图像 1,1
    • Loosen the strings by turning the tuning pegs.
  2. Fender Jazz Bass Strings Replacement: 步骤 2 中的图像 1,1
    • Once the strings are loose, remove them from the tuning pegs.
    • If you prefer, you can also cut the strings off.
  3. Fender Jazz Bass Strings Replacement: 步骤 3 中的图像 1,2 Fender Jazz Bass Strings Replacement: 步骤 3 中的图像 2,2
    • Reach under the bridge to pull out the end of each string.
  4. Fender Jazz Bass Strings Replacement: 步骤 4 中的图像 1,2 Fender Jazz Bass Strings Replacement: 步骤 4 中的图像 2,2
    • Insert the end of the string with no knob on the bottom through the bridge first.
    • Pull each string through to the top of the neck.
  5. Fender Jazz Bass Strings Replacement: 步骤 5 中的图像 1,1
    • Insert the strings into the indentations on the nut.
    • Wrap the strings around the tuning pegs about two times.
  6. Fender Jazz Bass Strings Replacement: 步骤 6 中的图像 1,2 Fender Jazz Bass Strings Replacement: 步骤 6 中的图像 2,2
    • Tighten the tuning pegs until the bass is in tune.
    • The standard tuning for a bass is E A D G.
    • You will have excess string hanging off the pegs of the bass.
终点
另外一个人完成了本指南。
团队
CSU Los Angeles, Team 1-1, Briggs Spring 2022 CSU Los Angeles, Team 1-1, Briggs Spring 2022 的会员
CSULA-BRIGGS-S22S1G1
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 31
总计 511
