跳转到主内容
Fender Frontman 15r Speaker Replacement
你所需要的
  1. Fender Frontman 15r Speaker Replacement, Back panel: 步骤 1 中的图像 1,1
    • Be sure to unplug the device before proceeding.
    • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
  2. Fender Frontman 15r Speaker Replacement: 步骤 2 中的图像 1,1
    • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  3. Fender Frontman 15r Speaker Replacement: 步骤 3 中的图像 1,1
    • Once the top is separated, use your hand to remove the back panel from the unit.
  4. Fender Frontman 15r Speaker Replacement, Speaker: 步骤 4 中的图像 1,1
    • Using tape or a post-it, label the input and output wires on the reverb. Remove these wires from the box.
  5. Fender Frontman 15r Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the two female connection terminals from the speaker terminals.
  6. Fender Frontman 15r Speaker Replacement: 步骤 6 中的图像 1,1
    • Use a Philips #1 screwdriver to remove the four 21.9 mm Phillips screws from the perimeter of the speaker.
  7. Fender Frontman 15r Speaker Replacement: 步骤 7 中的图像 1,2 Fender Frontman 15r Speaker Replacement: 步骤 7 中的图像 2,2
    • Gently remove the speaker.
结论
To install the new speaker, follow the instructions given in reverse.
另外一个人完成了本指南。
Stephen Figueira
于10/04/12注册
142 声望
创作了3篇指南
团队
Cal Poly, Team 24-30, Regan Fall 2012 Cal Poly, Team 24-30, Regan Fall 2012 的会员
CPSU-REGAN-F12S24G30
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 8,482
