跳转到主内容
Fender Frontman 15r Reverb Tank Replacement
你所需要的
  1. Fender Frontman 15r Reverb Tank Replacement, Remove the Back Plate: 步骤 1 中的图像 1,2 Fender Frontman 15r Reverb Tank Replacement, Remove the Back Plate: 步骤 1 中的图像 2,2
    • Remove 6 Phillips screws securing the back plate.
    • Lift the back panel out of the amp.
    • Gently pry with a flathead screwdriver or other tool to release the back panel if it's stuck.
    • Be careful not to pull out the wires connected to the power converter.
  2. Fender Frontman 15r Reverb Tank Replacement, Free the Reverb Tank: 步骤 2 中的图像 1,2 Fender Frontman 15r Reverb Tank Replacement, Free the Reverb Tank: 步骤 2 中的图像 2,2
    • Saw the adhesive from in between the reverb tank and the cabinet until the reverb tank is released.
  3. Fender Frontman 15r Reverb Tank Replacement, Free the Connecting Wires: 步骤 3 中的图像 1,1
    • Use wire cutters to remove the zip tie fastening the wires to the speaker.
  4. Fender Frontman 15r Reverb Tank Replacement, Disconnect Wires from Motherboard: 步骤 4 中的图像 1,2 Fender Frontman 15r Reverb Tank Replacement, Disconnect Wires from Motherboard: 步骤 4 中的图像 2,2
    • Unplug the wires leading from the reverb tank to the motherboard.
    • Notice they are plugged in where the motherboard is labeled "reverb only."
  5. Fender Frontman 15r Reverb Tank Replacement, Remove Reverb Tank: 步骤 5 中的图像 1,1
    • Remove the reverb tank.
  6. Fender Frontman 15r Reverb Tank Replacement, Install New Reverb Tank: 步骤 6 中的图像 1,1
    • Glue the new reverb tank into place following the directions provided with the glue or epoxy of your choice.
  7. Fender Frontman 15r Reverb Tank Replacement, Test the New Reverb Tank: 步骤 7 中的图像 1,1
    • Reconnect the wires and test the new reverb tank ensuring the effect properly matches the knob setting.
结论
Sam Omiotek
于02/25/19注册
72,896 声望
创作了288篇指南
2条评论
I guess there is 2 versions of this amp the one in this video this version of the tank has 3 springs; this looks like 2…
Wonder which one was the newer version?
https://www.youtube.com/watch?v=o856fDGI...
John Ender - 回复
Interesting! I wouldn’t know which is the newer version, but the one in the YouTube video does look like it has higher quality parts…
Sam Omiotek -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 41
总计 2,339
