跳转到主内容
Fender Frontman 15r Mounting Bracket Replacement
你所需要的
  1. Fender Frontman 15r Mounting Bracket Replacement, Back panel: 步骤 1 中的图像 1,1
    • Be sure to unplug the device before proceeding.
    • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
  2. Fender Frontman 15r Mounting Bracket Replacement: 步骤 2 中的图像 1,1
    • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  3. Fender Frontman 15r Mounting Bracket Replacement: 步骤 3 中的图像 1,1
    • Once the top is separated, use your hand to remove the back panel from the unit.
  4. Fender Frontman 15r Mounting Bracket Replacement, Mounting Bracket: 步骤 4 中的图像 1,2 Fender Frontman 15r Mounting Bracket Replacement, Mounting Bracket: 步骤 4 中的图像 2,2
    • There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
  5. Fender Frontman 15r Mounting Bracket Replacement: 步骤 5 中的图像 1,1
    • Label and unplug the two red wires connecting the mounting bracket to the speaker by pulling them off the nodes.
  6. Fender Frontman 15r Mounting Bracket Replacement: 步骤 6 中的图像 1,3 Fender Frontman 15r Mounting Bracket Replacement: 步骤 6 中的图像 2,3 Fender Frontman 15r Mounting Bracket Replacement: 步骤 6 中的图像 3,3
    • Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp.
  7. Fender Frontman 15r Mounting Bracket Replacement: 步骤 7 中的图像 1,3 Fender Frontman 15r Mounting Bracket Replacement: 步骤 7 中的图像 2,3 Fender Frontman 15r Mounting Bracket Replacement: 步骤 7 中的图像 3,3
    • Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front.
结论
Once the old bracket is removed, install the new one by following the instructions in reverse.
Greg Sawers
于09/27/12注册
85 声望
创作了3篇指南
团队
Cal Poly, Team 24-30, Regan Fall 2012 Cal Poly, Team 24-30, Regan Fall 2012 的会员
CPSU-REGAN-F12S24G30
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 4,842
