跳转到主内容
Fender Frontman 15r Fuse Replacement
你所需要的
  1. Fender Frontman 15r Fuse Replacement, Fuse: 步骤 1 中的图像 1,3 Fender Frontman 15r Fuse Replacement, Fuse: 步骤 1 中的图像 2,3 Fender Frontman 15r Fuse Replacement, Fuse: 步骤 1 中的图像 3,3
    • Be sure to unplug the device before proceeding.
    • Insert any tool with a small, flat end (such as a spudger, flathead screwdriver or plastic opening tool) into the groove in the bottom of the power input and wedge the plastic slot out from the amp.
    • There will be two compartments (one enclosed, one exposed) each containing a fuse. The exposed fuse is the active fuse and the enclosed one is a spare.
  2. Fender Frontman 15r Fuse Replacement: 步骤 2 中的图像 1,2 Fender Frontman 15r Fuse Replacement: 步骤 2 中的图像 2,2
    • Remove the blown exposed fuse and replace it with the enclosed fuse. If there is not an extra enclosed fuse, a new fuse must be ordered and inserted into the exposed slot.
结论
另外一个人完成了本指南。
Stephen Figueira
于10/04/12注册
140 声望
创作了3篇指南
团队
Cal Poly, Team 24-30, Regan Fall 2012 Cal Poly, Team 24-30, Regan Fall 2012 的会员
CPSU-REGAN-F12S24G30
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 44
总计 13,429
