简介
Speakers are the key parts within an amplifier that produce the final sound of your guitar strokes. There are two main reasons for replacing a speaker: blowing out the previous ones or upgrading for better sound and overall tone. Regardless of the reason this guide will take you through the removal and installation steps of this guide.
你所需要的
Take off the back panel by unscrewing the four Phillips head screws on the back of the amplifier.
Remove all the screws on the perimeter of the speaker. Use locking pliers to remove the nuts. There are eight bolts holding the speaker in place.
Pull the old speaker off of the board and insert the new speaker the same way you removed the old one.
When tightening the nuts back down on the bolts, be sure to tighten them by alternating, working in diagonals. (i.e. once you tighten one down go diagonal from it and work on the next one.
Repeat with the other speaker if necessary.
4等其他人完成本指南。
附加文件
2条评论
Thanks for the tutorial.
