跳转到主内容
Fender '65 Tube Amp Speaker Replacement
你所需要的
  1. Fender '65 Tube Amp Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Lay the amplifier face-down.
  2. Fender '65 Tube Amp Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove both back plates by unscrewing eight 1.2 mm screws with a Phillips #1 screwdriver.
    • Keep track of the eyelets.
  3. Fender '65 Tube Amp Speaker Replacement: 步骤 3 中的图像 1,2 Fender '65 Tube Amp Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the power stage vacuum tubes. Gently pull out the tube while simultaneously pressing down the metal holder.
  4. Fender '65 Tube Amp Speaker Replacement: 步骤 4 中的图像 1,3 Fender '65 Tube Amp Speaker Replacement: 步骤 4 中的图像 2,3 Fender '65 Tube Amp Speaker Replacement: 步骤 4 中的图像 3,3
    • Remove the positive and negative speaker connections and label them accordingly with a marker and painter's tape.
  5. Fender '65 Tube Amp Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the other side of the speaker connection from the internal speaker input jack.
  6. Fender '65 Tube Amp Speaker Replacement: 步骤 6 中的图像 1,3 Fender '65 Tube Amp Speaker Replacement: 步骤 6 中的图像 2,3 Fender '65 Tube Amp Speaker Replacement: 步骤 6 中的图像 3,3
    • Remove the reverb tank by unscrewing two 1.2 mm screws with a Phillips #1 screwdriver and unfastening the velcro by hand.
    • The wire must stay connected.
  7. Fender '65 Tube Amp Speaker Replacement: 步骤 7 中的图像 1,3 Fender '65 Tube Amp Speaker Replacement: 步骤 7 中的图像 2,3 Fender '65 Tube Amp Speaker Replacement: 步骤 7 中的图像 3,3
    • Remove the speaker by unscrewing four 1.2 mm screws with a Phillips #1 screwdriver.
    • Potential for device damage: Do not touch the front of the speaker when handling.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 58
