跳转到主内容
Fast Fix Shower Curtain Permanent Rod Replacement
你所需要的
  1. Fast Fix Shower Curtain Permanent Rod Replacement, Shower Curtain Permanent Rod Replacement: 步骤 1 中的图像 1,1
    • Use a measuring tape to measure the length of the rod in order to make sure the replacement is the same length.
  2. Fast Fix Shower Curtain Permanent Rod Replacement: 步骤 2 中的图像 1,2 Fast Fix Shower Curtain Permanent Rod Replacement: 步骤 2 中的图像 2,2
    • Using your flathead screwdriver or your screwdriver gun, loosen the screw by turning it counterclockwise.
  3. Fast Fix Shower Curtain Permanent Rod Replacement: 步骤 3 中的图像 1,1
    • Remove the old rod as well as the brackets.
  4. Fast Fix Shower Curtain Permanent Rod Replacement: 步骤 4 中的图像 1,1
    • Use disinfecting wipes to clean the area on the wall where the old brackets were.
  5. Fast Fix Shower Curtain Permanent Rod Replacement: 步骤 5 中的图像 1,1
    • Grab your new shower curtain rod.
    • If preferred, hold your old shower curtain rod against your new one to make sure they are both the same size.
  6. Fast Fix Shower Curtain Permanent Rod Replacement: 步骤 6 中的图像 1,2 Fast Fix Shower Curtain Permanent Rod Replacement: 步骤 6 中的图像 2,2
    • Lastly, using your flat head screwdriver or screwdriver gun, rotate the screw clockwise to tighten the screw.
结论
To reassemble your device, follow these instructions in reverse order
2等其他人完成本指南。
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 21
总计 803
