跳转到主内容
Fast Fix Shower Curtain Permanent Rod Replacement
你所需要的
  1. Fast Fix Shower Curtain Permanent Rod Replacement, Shower Curtain Permanent Rod Replacement: 步骤 1 中的图像 1,1
    • Use a measuring tape to measure the length of the rod in order to make sure the replacement is the same length.
  2. Fast Fix Shower Curtain Permanent Rod Replacement: 步骤 2 中的图像 1,2 Fast Fix Shower Curtain Permanent Rod Replacement: 步骤 2 中的图像 2,2
    • Using your flathead screwdriver or your screwdriver gun, loosen the screw by turning it counterclockwise.
  3. Fast Fix Shower Curtain Permanent Rod Replacement: 步骤 3 中的图像 1,1
    • Remove the old rod as well as the brackets.
  4. Fast Fix Shower Curtain Permanent Rod Replacement: 步骤 4 中的图像 1,1
    • Use disinfecting wipes to clean the area on the wall where the old brackets were.
  5. Fast Fix Shower Curtain Permanent Rod Replacement: 步骤 5 中的图像 1,1
    • Grab your new shower curtain rod.
    • If preferred, hold your old shower curtain rod against your new one to make sure they are both the same size.
  6. Fast Fix Shower Curtain Permanent Rod Replacement: 步骤 6 中的图像 1,2 Fast Fix Shower Curtain Permanent Rod Replacement: 步骤 6 中的图像 2,2
    • Lastly, using your flat head screwdriver or screwdriver gun, rotate the screw clockwise to tighten the screw.
结论
To reassemble your device, follow these instructions in reverse order
另外一个人完成了本指南。
Abdul-Jabbar Mohamed
于09/15/20注册
134 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 27
总计 411
