跳转到主内容
Roof Shingle Replacement
你所需要的
  1. Roof Shingle Replacement, Roof shingle: 步骤 1 中的图像 1,1
    • Remove the broken shingle by lifting the nails with the claw side of a hammer.
    • Use caution when handling a hammer and nails.
  2. Roof Shingle Replacement: 步骤 2 中的图像 1,1
    • Remove the single broken shingle, carefully, without ripping out the shingles above.
  3. Roof Shingle Replacement: 步骤 3 中的图像 1,1
    • Remove the adhesion strip off of the new shingle.
  4. Roof Shingle Replacement: 步骤 4 中的图像 1,1
    • Slip the new shingle in place, and line it up where the old shingle previously was.
  5. Roof Shingle Replacement: 步骤 5 中的图像 1,2 Roof Shingle Replacement: 步骤 5 中的图像 2,2
    • Secure the shingle with three 7/8" roofing nails.
    • Be careful when hammering in the nails.
  6. Roof Shingle Replacement: 步骤 6 中的图像 1,1
    • Slightly lift the edges of the shingle and apply a thin layer of cement along it.
  7. Roof Shingle Replacement: 步骤 7 中的图像 1,1
    • Press down the edges to lock the shingle in place.
结论
Marie Albrecht
于01/19/18注册
145 声望
撰写一个指南
2条评论
Great post! Roof repair is something you should only really do as a quick patch though. If one of your shingles has fallen off, odds are a lot more of them are going to be falling off soon too. You need to find the Best Quality shingles just to make sure that they stay on as long as your other ones.
Best Quality - 回复
Yeah those 3 in 1s are definitely NOT good quality, they are old and soon to be extinct. (Good riddance)
OOtysweat97 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 13
总计 412
