跳转到主内容
Tonneau Trifold Bed Cover Retention Pin Replacement
你所需要的
  1. Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: 步骤 1 中的图像 1,3 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: 步骤 1 中的图像 2,3 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: 步骤 1 中的图像 3,3
    • Locate the two screws on the retaining latch.
    • Use an Allen Wrench to loosen the screws.
    • The screws are tight and may require significant force.
  2. Tonneau Trifold Bed Cover Retention Pin Replacement: 步骤 2 中的图像 1,2 Tonneau Trifold Bed Cover Retention Pin Replacement: 步骤 2 中的图像 2,2
    • Continue loosening the screws until they are both loose enough to remove by hand.
  3. Tonneau Trifold Bed Cover Retention Pin Replacement: 步骤 3 中的图像 1,3 Tonneau Trifold Bed Cover Retention Pin Replacement: 步骤 3 中的图像 2,3 Tonneau Trifold Bed Cover Retention Pin Replacement: 步骤 3 中的图像 3,3
    • Grab both screws and pull them straight out.
    • Line up the holes on the replacement latch, then insert the new screws.
  4. Tonneau Trifold Bed Cover Retention Pin Replacement: 步骤 4 中的图像 1,3 Tonneau Trifold Bed Cover Retention Pin Replacement: 步骤 4 中的图像 2,3 Tonneau Trifold Bed Cover Retention Pin Replacement: 步骤 4 中的图像 3,3
    • Hand tighten both of the bolts onto the new latch.
  5. Tonneau Trifold Bed Cover Retention Pin Replacement: 步骤 5 中的图像 1,2 Tonneau Trifold Bed Cover Retention Pin Replacement: 步骤 5 中的图像 2,2
    • Tighten both screws evenly until the latch is held firmly in place.
    • Do not over tighten - you could break the Allen Wrench or strip the screws!
结论
To reassemble your device, follow these instructions in order.
Christopher King
于01/16/18注册
139 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 688
