跳转到主内容
修复你的物品
维修的权力
商店
简介
With this step by step repair guide, you will be able to replace a fog light for a 2005 Jeep Liberty.
  1. Open the hood to access the radiator grill tabs.
    • Open the hood to access the radiator grill tabs.
    • Pull up on the first tab and repeat for the remaining four tabs.
  2. Tilt the radiator grill cover forward and lift up and out to remove.
    • Tilt the radiator grill cover forward and lift up and out to remove.
  3. Using an allen wrench,  turn the tension screw counter-clockwise to loosen the light housing.
    • Using an allen wrench, turn the tension screw counter-clockwise to loosen the light housing.
  4. Lift up on the tension screw to release the light housing.
    • Lift up on the tension screw to release the light housing.
  5. Using a flat-head screwdriver, pull the tab outward to remove the light housing.
    • Using a flat-head screwdriver, pull the tab outward to remove the light housing.
    • Repeat the procedure for the right side of the light housing.
  6. Pull the light housing toward you.
    • Pull the light housing toward you.
  7. Remove the wiring harness from the light socket by lifting up on the tab with a flat-head screwdriver.
    • Remove the wiring harness from the light socket by lifting up on the tab with a flat-head screwdriver.
  8. Remove the light socket from the light housing by turning counter-clockwise.
    • Remove the light socket from the light housing by turning counter-clockwise.
  9. Remove the light socket from the light housing and replace.
    • Remove the light socket from the light housing and replace.
    • The light socket part number is 9145 and can be purchased at any auto parts store.
    • Install the new light socket back into the light housing by turning clockwise.
    • Plug the wiring harness back in the light socket.
结论
Test the replacement light socket by turning the lights on. If working, reinstall the light housing and radiator grill cover.
另外一个人完成了本指南。
CHARLES CATLEDGE
于2017年09月17日注册
161 信誉积分
撰写一个指南
团队
Thank you for your information, if you are looking for a place that sells the best and most trusted car fog lamps. Check this out!
vievie aryanti - 回复
添加评论
浏览统计数据:
过去的24小时: 14
过去的7天: 75
过去的30天: 352
总计 3,511
