跳转到主内容
Fast Fix FOB Battery Replacement
你所需要的
  1. Fast Fix FOB Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Purchase two CR2016 batteries.
    • You can find these at your local drugstore or hardware store.
  2. Fast Fix FOB Battery Replacement: 步骤 2 中的图像 1,2 Fast Fix FOB Battery Replacement: 步骤 2 中的图像 2,2
    • Use a small and thin object, like a penny or other coin, to pry open the FOB. It will separate into two pieces.
  3. Fast Fix FOB Battery Replacement: 步骤 3 中的图像 1,1
    • Identify which part of the FOB holds the battery. You should be able to clearly see the circular batteries in one half.
    • You should be able to clearly see the circular batteries in one half. You will not the need the other part of the FOB until the end.
  4. Fast Fix FOB Battery Replacement: 步骤 4 中的图像 1,2 Fast Fix FOB Battery Replacement: 步骤 4 中的图像 2,2
    • Remove both batteries from the FOB by releasing them from the prongs.
  5. Fast Fix FOB Battery Replacement: 步骤 5 中的图像 1,2 Fast Fix FOB Battery Replacement: 步骤 5 中的图像 2,2
    • Insert the new CR2016 batteries with the positive side facing down, and make sure the batteries are secure under the prongs.
  6. Fast Fix FOB Battery Replacement: 步骤 6 中的图像 1,3 Fast Fix FOB Battery Replacement: 步骤 6 中的图像 2,3 Fast Fix FOB Battery Replacement: 步骤 6 中的图像 3,3
    • Put the FOB back together.
    • You should hear a click that secures the two pieces in place.
终点
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 27
总计 726
