跳转到主内容
Fast Fix Dryer Vent Hose Replacement
你所需要的
  1. Fast Fix Dryer Vent Hose Replacement, Dryer Vent Hose: 步骤 1 中的图像 1,3 Fast Fix Dryer Vent Hose Replacement, Dryer Vent Hose: 步骤 1 中的图像 2,3 Fast Fix Dryer Vent Hose Replacement, Dryer Vent Hose: 步骤 1 中的图像 3,3
    • The first step is to locate the dryer vent hose where it attaches to the dryer. You will then detach the dryer hose from the exhaust port, and clean any lint that has gathered there.
  2. Fast Fix Dryer Vent Hose Replacement: 步骤 2 中的图像 1,3 Fast Fix Dryer Vent Hose Replacement: 步骤 2 中的图像 2,3 Fast Fix Dryer Vent Hose Replacement: 步骤 2 中的图像 3,3
    • The next step is to locate the dryer vent, which should be on the outside of the house. You will detach the dryer vent by unscrewing the four screws holding it to the house. Then you will dispose of the old dryer hose/tube.
  3. Fast Fix Dryer Vent Hose Replacement: 步骤 3 中的图像 1,2 Fast Fix Dryer Vent Hose Replacement: 步骤 3 中的图像 2,2
    • The third step is to attach the new dryer vent hose. You will slip it onto the dryer's exhaust port.
  4. Fast Fix Dryer Vent Hose Replacement: 步骤 4 中的图像 1,1
    • The fourth step is to secure the new dryer hose with a dryer tube clamp.
  5. Fast Fix Dryer Vent Hose Replacement: 步骤 5 中的图像 1,3 Fast Fix Dryer Vent Hose Replacement: 步骤 5 中的图像 2,3 Fast Fix Dryer Vent Hose Replacement: 步骤 5 中的图像 3,3
    • The fifth step is to make sure your new dryer hose is strung through to the outside dryer vent.
  6. Fast Fix Dryer Vent Hose Replacement: 步骤 6 中的图像 1,2 Fast Fix Dryer Vent Hose Replacement: 步骤 6 中的图像 2,2
    • The sixth step is to slip on the other dryer tube clamp in order to secure it to the outdoor dryer vent.
  7. Fast Fix Dryer Vent Hose Replacement: 步骤 7 中的图像 1,2 Fast Fix Dryer Vent Hose Replacement: 步骤 7 中的图像 2,2
    • The last step is to rescuer the clean dryer vent to the outside of the house using screws.
结论
2等其他人完成本指南。
Rachel Chapman
于06/07/23注册
181 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 20
总计 151
