跳转到主内容
Fast Fix Box Cutter Blade Replacement
你所需要的
  1. Fast Fix Box Cutter Blade Replacement, Blade: 步骤 1 中的图像 1,3 Fast Fix Box Cutter Blade Replacement, Blade: 步骤 1 中的图像 2,3 Fast Fix Box Cutter Blade Replacement, Blade: 步骤 1 中的图像 3,3
    • The case screw can easily be removed by using a Stanley #2 screwdriver or any other #2 screwdriver.
  2. Fast Fix Box Cutter Blade Replacement: 步骤 2 中的图像 1,1
    • Separate casing by simply pulling apart both halves.
  3. Fast Fix Box Cutter Blade Replacement: 步骤 3 中的图像 1,2 Fast Fix Box Cutter Blade Replacement: 步骤 3 中的图像 2,2
    • Carefully, using the pull tab, take out the blade holder and set it on the table.
    • Remove the blade by carefully sliding it out of the holder.
    • Be very careful when dealing with the blade as it is sharp.
  4. Fast Fix Box Cutter Blade Replacement: 步骤 4 中的图像 1,2 Fast Fix Box Cutter Blade Replacement: 步骤 4 中的图像 2,2
    • Replace the old blade with the new blade by carefully sliding it into the blade holder.
    • Place the blade holder back into the casing using the pull tab to hold it.
  5. Fast Fix Box Cutter Blade Replacement: 步骤 5 中的图像 1,2 Fast Fix Box Cutter Blade Replacement: 步骤 5 中的图像 2,2
    • Add grease to the sliding mechanism
    • Use either a paper towel or a cloth to spread the grease around the sliding mechanism.
  6. Fast Fix Box Cutter Blade Replacement: 步骤 6 中的图像 1,2 Fast Fix Box Cutter Blade Replacement: 步骤 6 中的图像 2,2
    • Take the other half without the blade and put it back together with the other half with the blade.
    • Snap the two parts together.
    • Place the screw back in to hole while holding the casing together.
  7. Fast Fix Box Cutter Blade Replacement: 步骤 7 中的图像 1,2 Fast Fix Box Cutter Blade Replacement: 步骤 7 中的图像 2,2
    • Use Stanley #2, or any other #2, screwdriver to screw the casing back together.
    • To ensure proper placement of the blade, activate the mechanism that slides the blade out.
    • Once it comes out, like in second picture, you are done.
结论
Peace Adeyemo
于02/22/18注册
145 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 57
总计 8,871
