跳转到主内容
Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement
你所需要的
  1. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement, 2006 Honda CR-V Key Fob: 步骤 1 中的图像 1,1
    • You will need to take the key off the ring.
  2. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 步骤 2 中的图像 1,1
    • The second step is to take out the little screw on the back side of the key.
  3. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 步骤 3 中的图像 1,1
    • Unclip the back part of your key.
    • This part is super fragile.
  4. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 步骤 4 中的图像 1,1
    • You will push the buttons from the front side to have the middle piece fall out.
  5. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 步骤 5 中的图像 1,2 Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 步骤 5 中的图像 2,2
    • Then you will unclip the middle part. There is one clip on each side of this piece. They are super fragile and can break easily.
  6. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 步骤 6 中的图像 1,2 Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 步骤 6 中的图像 2,2
    • Then push the buttons from the front side to push out a rubber insert.
  7. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 步骤 7 中的图像 1,1
    • Then peel out the mother chip and replace your rubber insert.
结论
2等其他人完成本指南。
2条评论
How do you remove the key from broken fob and put in new fob so you don’t have to incur the cost of cutting new key?
Me Me - 回复
Just open the fob, like in this tutorial. The key is just a piece of metal.
Then place the key in a new fob (or replace only the fob plastic case for a cheaper solution).
Brendan -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 47
总计 1,991
