跳转到主内容
How to Replace the Headlight in a 2010-2014 Volkswagen Jetta
你所需要的
  1. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: 步骤 1 中的图像 1,3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: 步骤 1 中的图像 2,3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: 步骤 1 中的图像 3,3
    • Turn the ignition fully off and open the hood of your vehicle.
    • The lever to open it is on the left hand side of the pedals. It’ll make a noticeable clunk sound when pulled the first time which releases the first of the two step hood opening procedure.
    • Make your way to the front of the car and push up on the lever underneath the hood to fully open the hood.
    • Use the hood prop rod to hold the hood open for the duration of the repair.
  2. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: 步骤 2 中的图像 1,3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: 步骤 2 中的图像 2,3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: 步骤 2 中的图像 3,3
    • Locate the plastic dust cover behind the burnt headlight and gently remove it. If the cover is stuck, you can use a screwdriver to pop it out.
  3. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: 步骤 3 中的图像 1,2 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: 步骤 3 中的图像 2,2
    • Once the cover is off, twist the light harness from the fixture in a counter clockwise rotation.
    • Pull the bulb to separate it from the connector.
    • Insert the new bulb in the correct orientation as the previous, and tighten it back into the headlight by rotating it clockwise.
  4. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: 步骤 4 中的图像 1,1
    • Reapply the dust cover and close the hood of the vehicle.
  5. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: 步骤 5 中的图像 1,1
    • Turn the ignition on and switch on the lights to test the new working headlight.
结论
To replace the other headlight. follow the same instructions.
Seyed-Mohammad Hosseiny
于09/22/20注册
159 声望
撰写一个指南
团队
6条评论
Am I missing something? Or is there a trick to those tabs to release the bulb?
Dez Petrovic - 回复
They are a pull to release mechanism. no need to undo tabs.
Seyed-Mohammad Hosseiny -
Don’t forget to wear gloves when handling halogen light bulbs!
Where’s the driving lights?
Ted Stoffers - 回复
I installed the new bulb but it still doesn’t work. My neighbor, a retired mechanic came to help and undid both and put back and now, both headlights don’t work. Any other advice?
Emilia Lievano - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 101
过去 30 天: 523
总计 20,816
