跳转到主内容
Farberware FSTO100 Power Supply Replacement
你所需要的
  1. Farberware FSTO100 Power Supply Replacement, Power Supply: 步骤 1 中的图像 1,1
    • Make sure the toaster is unplugged.
    • First, to remove the plastic bracket, turn toaster oven on its side.
  2. Farberware FSTO100 Power Supply Replacement: 步骤 2 中的图像 1,1
    • Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
  3. Farberware FSTO100 Power Supply Replacement: 步骤 3 中的图像 1,1
    • Use Phillips head screwdriver and pliers to remove screw and nut securing transformer.
  4. Farberware FSTO100 Power Supply Replacement: 步骤 4 中的图像 1,1
    • If the wire gets pulled out of the transformer, reinsert it.
    • Use a small flathead screwdriver to secure the screw that holds the wire in place.
结论
Tony Wang
于10/05/12注册
103 声望
创作了5篇指南
团队
Cal Poly, Team 6-35, Regan Fall 2012 Cal Poly, Team 6-35, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G35
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,407
