简介
按下按扭同时观察灰尘绒球清除情况。这种方法不能够完全清理干净设备。顽强的污渍或灰尘还会留在主板上与散热片等物体上。每间隔1到2月执行一次清洁功能延长你设备的寿命。脏污与灰尘的聚集是导致游戏设备损坏的头号杀手。
首先,确认没有磁盘在磁盘驱动器里。
如果你还有原版的PS3,你需要轻按控制器后面的开关把PS3从待机切换到关闭状态。长按退盘按钮不放再把控制器的开关打开。
如果你是PS3 Slim版本,你要先拔掉电源线,长按下退盘按钮不放,再插入电源线。
你的系统将会在数秒钟内启动,同时你会听到在PS3内的散热风扇开始转动,并且发出的声音比正常情况下要大许多。风扇转动可能会持续约15-20秒。在这次的演示下风扇约持续了16.96秒。
完成后,原版的控制器电源指示灯(红色)将会闪烁,Slim版的电源指示灯会完全关闭。
My fan isn't working anymore
That sucks..
That sucks..
如果你是原版系统,按下控制器后面的按钮关闭系统再切回待机状态。恭喜你已经完成 了!
如果你是Slim版,拔掉电源线后重新将电源线插回。恭喜你也已经完成 了!
Thanks a bunch. Mine only ran for about 10 seconds but the but the fan isn't loud anymore. :)
Awesome! Happy to help :)
Thank you…I'm a little behind the times…
每1到2月执行一次清洁功能测试将清理干净PS3的碎屑而有助于延长设备的使用寿命。
50等其他人完成本指南。
由衷感谢以下译者:
28%
Gaozhong正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
31条评论
Doesn't work on superslim eject button just releases the tray not electrical
taipancorbett,
Thanks for informing me. Honestly, I've seen this done with the original and personally preformed it on the slim and assumed that it worked with the super slim as well. Looks like I made an ass out of myself. I'll make the corrections to the guide.
That said, it stands to reason that it should have a way to detect an open lid. Has that been tried? Plugging it in with the lid open?
How can we do that on the super slim model? Or what the other option to do this self cleaning?
I'm afraid I don't know how to preform this test on the super slim. I would search youtube/web searches.
It works on the slim! Just gotta unplug, hold, replug! Once its done as you said, unplug and replug!
Of course it does :) it just doesn't work on the SUPER slim (CECH-4000)
Tom -
These fans last long even after much abuse. I just never understood why my CECH-2501 makes 3 beeps during the beginning of the test whereas my CECH-2001 and CECH-2101 doesn't ?
Tom -
I've had my Ps3 for about 5 years, and I've just decided that I wanted to clean out the dust out of my systems to ensure they live longer. Do you recommend still doing this to clean my Ps3 after so many years of neglecting the dust?
Absolutely! It should easily remove any loose dust bunnies that are residing inside your system but it won't get the stubborn stuff. You will have to gut the console if you really want to clean it completely.
Furthermore, if you're interested in dust prevention within your systems I would highly recommend purchasing dust covers for them.
Foamy Lizard products are form fitting to the PS4/XB1. I prefer these to Digital Deck Covers but they don't make them for older systems. If you have older systems you want covered, i.e. X360/PS3 etc, defer to the second link. eBay also has a great selection of custom covers for various systems.
I’ve had my PS3 for 6 years and I haven’t done this before. Should I do this more than once to make sure it’s clean? I just did it right now and it was very loud and shaking like crazy, probably because of its old age. I’ve had this slim since release the only problems I’ve come to face with is me having to hold it up vertically so it could read discs, I was hoping this would change that.
The fan ramps up at its maximum RPM so it's not uncommon for the systems noise level to increase during this process. However, my system has never rattled like you are describing. I wouldn't think preforming the test again would do any harm but if it's a real concern I'd recommend taking the system apart and cleaning it. The fan test will only remove loose dust/dirt/debris from the system. Anything that's been sitting in there for years will require a small amount of elbow grease to clean this filth.
You could try taking the top cover off, preforming the test and see if you can locate what might be causing the shaking.
I would recommend also that if like me you've had your ps3 for a good could of years and never got it cleaned you have the thermal paste inside the system (it regulates the heat factor to avoid system from over heating) checked and change if need be. I did and found that the thermal paste in my system had dried out due to to dust build up
Our system will flash a message while in game play saying it's overheating then it shuts off shortly after but the odd thing is we won't even be paying it that long before it does that. Would this cleaning fix that or do you know what the problem could be that's causing it & how we can fix it ?
Brittney, it’s hard to say if this will solve the problem. It’s possible your system needs more work than a cleaning. However, start with this tutorial. If it still overheats take the top lid off and hit it with a can or air to remove further debris. If cleaning the system doesn’t resolve your issue then I’d advise seeking help in another repair guide.
Was really helpful, thanks. I have a ps3 slim (or 2 for that matter. One broken one works). Anyways on the older one the red light goes out after this but on the new one it blinks for some reason. Dunno why but i thought it's funny so i shared it XD
I did this and now my ps3 won't read discs can anyone help?
I'm afraid I haven't had this issue. Unsure what might have caused this. Have you attempted to open and investigate the problem?
there's no ejection button on my Slim
Then go find a replacement. You've got higher priorities before preforming this
This is fake I think because it's not working on my ps3 slim and I'm freaking out
That's a bold claim seeing as 28 others have marked that they have successfully followed these steps. 75k have viewed this page and while some can't get it to work, none have made the claim this is fake. If it was I'm quite sure ifixit would remove my post.
Has anybody figured out how to do this on the super slim model yet?? Been searching everywhere, no luck so far.
What if you forget to take out the disc?
I have a fat backwards compatible PS3 the fan test and clean dose not work it just beeps 3 times and nothing just like when you check and there is no disk in what needs to be done? I am also having a problem during game play only with a disk it shuts down and flashes red any advice for that?
Hello there,
I have the original PS3 model (the one that is all black, no silver stripe, and didn't have WiFi - CECHB01). When I try to do this, it just beeps and never turns on. Is there another method for this original launch model?
Thanks!
Thank you so much, my ps3 sounded more like an aircraft carrier and kept turning off 😊 saved the day.
My ps3 super slim spins for half a second and then stops
Matthew Hutson - 回复
I did the steps but it did nothing at all
Devin Vang - 回复
I cleaned it then did the self clean thing, and it did nothing the fan didn’t do it’s thing. Why???
Devin Vang - 回复
This is great! It worked. It’s like half as loud now. I have a ps3 120gb slim
Vince Craig - 回复
