跳转到主内容
加入维修社区 - 创建账户
Fan Coil Filter Replacement
你所需要的
  1. Fan Coil Filter Replacement, Fan Coil Filter Replacement: 步骤 1 中的图像 1,1
    • Clean the fan coil grilles using a paper towel and water.
    • Ensure that the register is thoroughly cleaned out before starting the filter replacement process.
  2. Fan Coil Filter Replacement: 步骤 2 中的图像 1,1
    • Close off each adjustable damper.
    • This will ensure that the register grille does not get in the way later on during the filter removal.
  3. Fan Coil Filter Replacement: 步骤 3 中的图像 1,2 Fan Coil Filter Replacement: 步骤 3 中的图像 2,2
    • Remove the screws from fan coil using a Phillips #1 screwdriver.
    • Open up the fan coil.
  4. Fan Coil Filter Replacement: 步骤 4 中的图像 1,1
    • Use your hands to remove the filter from the fan coil.
  5. Fan Coil Filter Replacement: 步骤 5 中的图像 1,2 Fan Coil Filter Replacement: 步骤 5 中的图像 2,2
    • Replace the fan coil filter.
    • Make sure to close the fan coil door after the filter replacement is completed.
  6. Fan Coil Filter Replacement: 步骤 6 中的图像 1,2 Fan Coil Filter Replacement: 步骤 6 中的图像 2,2
    • Screw in closed the fan coil door.
    • Open up each of the adjustable dampers for better air flow.
结论
Following these steps, you will be able to replace the filter in your fan coil system.
Abukar Ahmed
于09/20/20注册
133 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 25
总计 1,052
