跳转到主内容
加入维修社区 - 创建账户
Fan Blade Arm Replacement
你所需要的
  1. Fan Blade Arm Replacement, Fan Blade Arm: 步骤 1 中的图像 1,3 Fan Blade Arm Replacement, Fan Blade Arm: 步骤 1 中的图像 2,3 Fan Blade Arm Replacement, Fan Blade Arm: 步骤 1 中的图像 3,3
    • Make sure no power is flowing to the fan. Then begin by removing the metal light frame by twisting.
  2. Fan Blade Arm Replacement: 步骤 2 中的图像 1,2 Fan Blade Arm Replacement: 步骤 2 中的图像 2,2
    • Unscrew the finial (cover at the bottom of the glass globe). Then unscrew the hex nut and remove the rubber washer. This will allow the globe to be easily removed.
  3. Fan Blade Arm Replacement: 步骤 3 中的图像 1,3 Fan Blade Arm Replacement: 步骤 3 中的图像 2,3 Fan Blade Arm Replacement: 步骤 3 中的图像 3,3
    • Remove lightbulbs to avoid damage when removing light pan. Then, remove all three fitter plate screws. This will cause the light pan to hang from the electrical wires.
  4. Fan Blade Arm Replacement: 步骤 4 中的图像 1,2 Fan Blade Arm Replacement: 步骤 4 中的图像 2,2
    • Disconnect single pin connectors to finish removing light fixture from fan.
  5. Fan Blade Arm Replacement: 步骤 5 中的图像 1,2 Fan Blade Arm Replacement: 步骤 5 中的图像 2,2
    • Remove the three screws from the fitter plate. This will allow the plate to easily be separated from the fan.
  6. Fan Blade Arm Replacement: 步骤 6 中的图像 1,3 Fan Blade Arm Replacement: 步骤 6 中的图像 2,3 Fan Blade Arm Replacement: 步骤 6 中的图像 3,3
    • Remove the two screws securing the broken blade arm. Then separate the broken component from the fan.
  7. Fan Blade Arm Replacement: 步骤 7 中的图像 1,3 Fan Blade Arm Replacement: 步骤 7 中的图像 2,3 Fan Blade Arm Replacement: 步骤 7 中的图像 3,3
    • Replace the broken blade arm on the fan blade. There are two components that are placed on either side of the blade and secured together with screws.
结论
2等其他人完成本指南。
4指南评论
Where did you bought the replacement for that specific fan I’m looking for the arm and blades with the star
Maria Franco - 回复
I am as well and harbor breeze and Lowe's are absolutely no help!
Brandy Broussard - 回复
I’m looking for the same thing CANT find it anywhere I need the arm
Lisa - 回复
Where can I find an exact replacement.
Darrell Resler - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 72
总计 8,843
