当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
There is a small indentation in the side of the phone near the bottom of the back cover.
With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
There is a small indentation in the back of the phone just below the battery.
Use a fingernail in this indentation to push the battery toward the top of the phone
Pull the battery out away from the phone.
Use your finger to slide the SIM card straight down out of its tray.
Remove the SIM card from your Fairphone.
Repeat this procedure if you have a second SIM card.
Be sure to remove all SIM cards before servicing your phone.
If you have a microSD card, use your finger to slide it straight out of its slot.
Remove the microSD card from your phone.
The midframe is secured to the display assembly by several small plastic clips.
Use an opening pick to carefully pry the midframe away from the display assembly.
Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
Run the opening pick and pry along the top seam.
To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
Use tweezers to remove the volume rocker and power buttons from the display assembly.
During reassembly make sure the orientation of the buttons is correct. The rubber backings must fit into the channels in the assembly.
Use the flat end of a spudger to disconnect the antenna cable connector.
Make sure to only disconnect the connector from its socket, and not the entire socket from the board.
Do not try to remove the motherboard just yet, as it is still connected to the display assembly by the display data cable.
Gently lift the top end of the motherboard up to expose the display data cable.
The rear-facing camera may be adhered to the display assembly. Try to pry it and the motherboard up together.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
