跳转到主内容
Fairphone 1 Motherboard Replacement
你所需要的
  1. Fairphone 1 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,3 Fairphone 1 Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,3 Fairphone 1 Motherboard Replacement, Back Cover: 步骤 1 中的图像 3,3
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Fairphone 1 Motherboard Replacement: 步骤 2 中的图像 1,3 Fairphone 1 Motherboard Replacement: 步骤 2 中的图像 2,3 Fairphone 1 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Slide the back cover down and remove it from the phone.
  3. Fairphone 1 Motherboard Replacement, Battery: 步骤 3 中的图像 1,3 Fairphone 1 Motherboard Replacement, Battery: 步骤 3 中的图像 2,3 Fairphone 1 Motherboard Replacement, Battery: 步骤 3 中的图像 3,3
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Fairphone 1 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the battery from your Fairphone.
  5. Fairphone 1 Motherboard Replacement, SIM and MicroSD Card: 步骤 5 中的图像 1,3 Fairphone 1 Motherboard Replacement, SIM and MicroSD Card: 步骤 5 中的图像 2,3 Fairphone 1 Motherboard Replacement, SIM and MicroSD Card: 步骤 5 中的图像 3,3
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
  6. Fairphone 1 Motherboard Replacement: 步骤 6 中的图像 1,2 Fairphone 1 Motherboard Replacement: 步骤 6 中的图像 2,2
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
  7. Fairphone 1 Motherboard Replacement, Midframe Assembly: 步骤 7 中的图像 1,1
    • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
  8. Fairphone 1 Motherboard Replacement: 步骤 8 中的图像 1,3 Fairphone 1 Motherboard Replacement: 步骤 8 中的图像 2,3 Fairphone 1 Motherboard Replacement: 步骤 8 中的图像 3,3
    • The midframe is secured to the display assembly by several small plastic clips.
    • Use an opening pick to carefully pry the midframe away from the display assembly.
    • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
  9. Fairphone 1 Motherboard Replacement: 步骤 9 中的图像 1,2 Fairphone 1 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Carefully round the corner, separating the midframe from the display assembly.
  10. Fairphone 1 Motherboard Replacement: 步骤 10 中的图像 1,1
    • After rounding the next corner, the midframe should be free along the bottom and the sides.
  11. Fairphone 1 Motherboard Replacement: 步骤 11 中的图像 1,3 Fairphone 1 Motherboard Replacement: 步骤 11 中的图像 2,3 Fairphone 1 Motherboard Replacement: 步骤 11 中的图像 3,3
    • Run the opening pick and pry along the top seam.
    • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
  12. Fairphone 1 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Separate any remaining clips and remove the midframe from the phone.
  13. Fairphone 1 Motherboard Replacement, Motherboard Assembly: 步骤 13 中的图像 1,3 Fairphone 1 Motherboard Replacement, Motherboard Assembly: 步骤 13 中的图像 2,3 Fairphone 1 Motherboard Replacement, Motherboard Assembly: 步骤 13 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove the volume rocker and power buttons from the display assembly.
    • During reassembly make sure the orientation of the buttons is correct. The rubber backings must fit into the channels in the assembly.
  14. Fairphone 1 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Use the flat end of a spudger to disconnect the antenna cable connector.
    • Make sure to only disconnect the connector from its socket, and not the entire socket from the board.
  15. Fairphone 1 Motherboard Replacement: 步骤 15 中的图像 1,2 Fairphone 1 Motherboard Replacement: 步骤 15 中的图像 2,2
    • Use tweezers to remove the adhesive foam tape from the top of the digitizer cable ZIF socket.
  16. Fairphone 1 Motherboard Replacement: 步骤 16 中的图像 1,3 Fairphone 1 Motherboard Replacement: 步骤 16 中的图像 2,3 Fairphone 1 Motherboard Replacement: 步骤 16 中的图像 3,3
    • Use the tip of a spudger to flip open the tab on the digitizer ZIF connector.
    • Use tweezers to pull the digitizer cable away from its socket on the motherboard.
  17. Fairphone 1 Motherboard Replacement: 步骤 17 中的图像 1,1
    • Remove the three 2.5 mm Phillips #000 screws securing the motherboard to the display assembly.
  18. Fairphone 1 Motherboard Replacement: 步骤 18 中的图像 1,2 Fairphone 1 Motherboard Replacement: 步骤 18 中的图像 2,2
    • Do not try to remove the motherboard just yet, as it is still connected to the display assembly by the display data cable.
    • Gently lift the top end of the motherboard up to expose the display data cable.
    • The rear-facing camera may be adhered to the display assembly. Try to pry it and the motherboard up together.
  19. Fairphone 1 Motherboard Replacement: 步骤 19 中的图像 1,2 Fairphone 1 Motherboard Replacement: 步骤 19 中的图像 2,2
    • Use the tip of a spudger to disconnect the display data cable from the back of the motherboard.
  20. Fairphone 1 Motherboard Replacement: 步骤 20 中的图像 1,1
    • Remove the motherboard from the display assembly.
  21. Fairphone 1 Motherboard Replacement, Rear Camera: 步骤 21 中的图像 1,3 Fairphone 1 Motherboard Replacement, Rear Camera: 步骤 21 中的图像 2,3 Fairphone 1 Motherboard Replacement, Rear Camera: 步骤 21 中的图像 3,3
    • Use the flat end of a spudger to disconnect the rear-facing camera cable connector from its socket on the motherboard.
    • Remove the rear facing camera from the motherboard.
  22. Fairphone 1 Motherboard Replacement, Motherboard: 步骤 22 中的图像 1,1
    • Motherboard remains.
    • Remember to remove all the plastic seals of the new motherboard. You will find at least one covering the microphone for dust protection.
结论
8等其他人完成本指南。
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,077篇指南
一条评论
This is a wonderful and detailed guide - thank you. However, I followed the instructions precisely and whilst the phone now switches on perfectly, the touchscreen does not work. Thoughts on how ifixthat welcome!!
Anthe George - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 9,366
